lamlam
1
hi,i just install expresscache 1.3 and everything was ok.
when the installation was completed,i reboot. after reboot,i get the message :
ExpressCache
ExpressCache can not launch.
Try using the original user account for the first time.
OK
i do use the original user,how to do with this? thanks
Try a complete uninstall of ExpressCache and clear the Temp directory then reinstall ExpressCache 1.3.0
- Uninstall ExpressCache and reboot the system
- Navigate to the following location
for 64bit system: C:\Program Files (x86)\SanDisk\
for 32bit system: C:\Program Files\SanDisk
- Delete the ExpressCache folder
- Open the Registry editor: Run regedit.exe
- Go to HKEY_LOCAL_MACHINE\SOFTWARE\SanDisk and delete ExpressCache
Next we need to clear the Temp directory
- Navigate to the Temp directory (typically C:\Users|<Your logon name>\Local\Temp
- Highlight and delete all files in the Temp directory
- Reboot the PC
