Highlighted
Newbie
Problem with Cloudspeed 1000 "SDLFGD7R-480G-1HA1"
I have this old SSD sitting around that I want to use on a new computer I got.
I had it working once on my mom's Mac Mini, but she didn't like it (I forget the exact issue), so she made me take it back!
I think I enabled TRIM on the volume and that might have been a mistake, I can't remember.
On Sandisk SSD Dashboard 2.7.0.0 it says:
Model: SDLFGD7R-480G-1HA1
Firmware Version: ZN19MC49
Drive Health: Normal
Notifications: None
Security: ATA: Not Enabled
SATA Revision: 3.0,6 Gb/s
SATA Link Speed: 6.0 Gb/s
Serial Number: FG00B4PP
Maximum LBA: 937703087
WWN: 500117310027F454
4k Alignment: Yes
If I plug this into a SATA port on my Windows 10 computer, it seizes at bootup. It just sits there showing a flashing underline cursor!
So I got a USB adapter, booted into Windows, plugged into a USB port and got this information:
SDLFGD7R-480G-1HA1 USB Device Properties (drive manager):
General:
Device type: Disk drives
Manufacturer: (Standard disk drives)
Device status: This device is working properly.
Volumes:
Disk: Disk 6
Type: Unknown
Status: Not Initialized
Partition style: Not Applicable
Capacity: 457863 MB
Unallocated Space: 457863 MB
Reserved space: 0 MB
Driver:
Driver Provider: Microsoft
Driver Date: 2006-06-21
Driver Version: 10.0.18362.1
Digital Signer: Microsoft Windows
Details:
Hardware Ids: USBSTOR\DiskSDLFGD7R-480G-1HA1______ZN19
Events:
Device started (disk):
Device USBSTOR\Disk&Ven_SDLFGD7R&Prod_-480G-1HA1&Rev_ZN19\0000001270AF&0 was started.
Driver Name: disk.inf
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Service: disk
Lower Filters:
Upper Filters:
Device configured (disk.inf):
Device USBSTOR\Disk&Ven_SDLFGD7R&Prod_-480G-1HA1&Rev_ZN19\0000001270AF&0 was configured.
Driver Date: 06/21/2006
Driver Section: disk_install.NT
Driver Rank: 0xFF0006
Matching Device Id: GenDisk
Outranked Drivers: disk.inf:GenDisk:00FF2002
Device Updated: false
Parent Device: USB\VID_2109&PID_0711\0000001270AF
Device not migrated:
Device USBSTOR\Disk&Ven_SDLFGD7R&Prod_-480G-1HA1&Rev_ZN19\0000001270AF&0 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USBSTOR\Disk&Ven_Apple&Prod_iPod&Rev_1.70\000A27002243D534&0
Location Path:
Migration Rank: 0xF000FC000000F120
Present: false
Status: 0xC0000719
If I ask it to initialize disk (whether MBR or GPT), Windows 10 comes back with an error window that says, "incorrect function."
If I ask it to run S.M.A.R.T. diagnostic short test, it comes back "The S.M.A.R.T. diagnostic test failed."
Here's some reports from SanDiskGuard:
Diagnostic Summary
Date (UTC) = 2020-04-12 8:48:27 PM
Application Title = SanDiskGuard Special Edition
Application Version = 1.2.4.0
Serial Number = FG00B4PP
Part Number = SDLFGD7R-480G-1HA1
Firmware = ZN19MC49
Interface = SATA
WWN = 500117310027F454
Manufacturing Defects = 648
Grown Defects = 0
Power On Hours = 276
Temperature (C) = 40
Max Temperature (C) = 64
% Life Used = 0
SMART Error Log Version = 1
Error Log Index = 0
Device Error Count = 0
Checksum = 0
First Error Log Data:
Command # Device Control Feature (7:0) Count (7:0) LBA (7:0) LBA (15:8) LBA (23:16) Device Command Timestamp (ms)
5 01 03 00 00 00 20 58 23 1073741824
4 01 00 00 00 00 EC 58 23 0
3 00 00 00 00 00 00 00 00 0
2 00 00 00 00 00 00 00 00 0
1 00 00 00 00 00 00 00 00 0
Error Data Device Control Status Error (7:0) Count (7:0) LBA (7:0) LBA (15:8) LBA (23:16) Device Extended Error Info State Life Timestamp (ms)
00 02 03 00 00 00 51 0C 310007000000000000000000000000000000 EXE_SMART_SELF_TEST 1
Second Error Log Data:
5 C1 4C 00 00 00 00 01 00 3959422976
4 00 00 00 00 00 D0 01 00 2952839759
3 00 00 14 01 00 00 00 00 0
1 00 03 00 00 00 51 0C 02 458801
02 00 50 00 00 00 00 01 000000EC6C50000000D400014FC200B07F57 UNKNOWN 0
Third Error Log Data:
5 00 00 00 00 00 00 00 00 276
4 37 05 26 00 00 00 00 00 0
3 7F 57 00 00 00 04 00 01 1359004239
2 6C 50 00 00 00 D4 00 01 2952839759
1 02 50 00 00 00 00 01 00 3959422976
00 00 00 00 00 00 00 00 000000000000000000000000000000000000 UNKNOWN 0
Fourth Error Log Data:
5 00 00 00 00 00 00 00 00 0
4 00 00 00 00 00 00 00 00 0
Fifth Error Log Data:
Attribute Name Status Nominal Worst RawData Raw Decode
2 Internal File Check 1200 0 0 00000000000000
5 Retired Block Count 3200 100 100 00000000000000 Number of Retired Blocks=0
9 Power-On Hours 3200 100 100 14010000370800 Total Number of Power-On-Hours=276, Total Seconds since Last POH Update=2103
12 Power Cycle Count 3200 100 100 41020000000000 Cumulative Lifetime Power Cycle Count=577
13 Lifetime UECC Count 1200 120 120 08000000000000 Count of Uncorrectable ECC Errors=8
32 Write Amplification 0200 0 0 00000000000000 Write Amplification multiplied by 100=0
170 Reserved Blocks Remaining 3200 0 0 00000000000000 Reserved Block Count=0
171 Program Fail Count 3200 0 0 00000000000000 Program Error Count=0
172 Erase Fail Count 3200 0 0 00000000000000 Erase Error Count=0
174 Unexpected Power Loss Count 3200 0 0 00000000000000 Unexpected Power Loss Event Count=0
175 Power Loss Protection Failure 3200 0 0 00000000000000
177 Percent Drive Life Remaining 1200 0 0 64000000000000 Percent of Drive Life Remaining=100
180 End-to-Error Detection/Correction Rate 2200 0 0 00000000000000
181 Program Fail Count 2200 0 0 00000000000000 Program Error Count=0
182 Erase Fail Count 3200 0 0 00000000000000 Erase Error Count=0
190 Drive Temperature Warning 3200 60 64 28001A28000000 Current Temperature (C)=40, Lowest Temperature Recorded since Last Power Cycle (C)=26, Highest Temperature Recorded since Last Power Cycle (C)=40
194 Drive Temperature 2200 40 64 28001440000000 Current Temperature (C)=40, Lowest Temperature Recorded since First Power-On (C)=20, Highest Temperature Recorded since First Power-On (C)=64
195 Uncorrectable Error Count 1A00 120 120 00000000000000 Number of Uncorrectable Errors=0
196 Reallocation Event Count 1A00 100 100 00000000000000 Number of Blocks Reallocated=0
198 Offline Scan Uncorrectable Count 1000 0 0 00000000000000
199 UDMA CRC Error 1E00 0 0 00000000000000
233 Lifetime NAND Writes 3200 0 0 00000000000000 Number of 64GB Increments NAND Writes=0
241 Lifetime Bytes Written by Host 3200 0 0 40120000000000 Number of 64GB Increments Written by the Host=4672
242 Lifetime Bytes Read by Host 3200 0 0 400D0000000000 Number of 64GB Increments Read by the Host=3392
245 Percent of Drive Life Remaining 1200 0 0 00000000000000 Percent of Drive Life Remaining=0
Word Parameter Value
0 - 0 0_GeneralConfiguration 5A08h
1 - 1 1_Obsolete 3FFFh
2 - 2 2_SpecificConfiguration C837h
3 - 3 3_Obsolete 0010h
4 - 5 4_5_Retired 00000000h
6 - 6 6_Obsolete 003Fh
7 - 7 7_Reserved_CompactFlash1 0000h
8 - 8 8_Reserved_CompactFlash2 0000h
9 - 9 9_Retired 0000h
10 - 19 10_19_SerialNumber FG00B4PP
20 - 21 20_21_Retired 00004000h
22 - 22 22_Obsolete 0032h
23 - 24 23_24_ControllerRevision ZN19
25 - 26 25_26_FirmwareRevision MC49
27 - 46 27_46_ModelNumber SDLFGD7R-480G-1HA1
47 - 47 47_RW_MultipleCommand 8010h
48 - 48 48_TCG_Feature 0000h
49 - 49 49_Capability_Feature1 2F00h
50 - 50 50_Capability_Feature2 4001h
51 - 52 51_52_Obsolete 00000000h
53 - 53 53_Validity_Flags 0007h
54 - 58 54_58_Obsolete 3FFF0010003FFC1000FBh
59 - 59 59_Sanitize_Info 5100h
60 - 61 60_61_Total_User_LBAs FFFF0FFFh
62 - 62 62_Obsolete 0000h
63 - 63 63_DMA_Info 0007h
64 - 64 64_PIO_Mode 0003h
65 - 65 65_Minimum_MW_DMA_Time 0078h
66 - 66 66_Recomended_MW_DMA_Time 0078h
67 - 67 67_Min_PIO_Time_no_Flow_CTL 0078h
68 - 68 68_Min_PIO_Time_with_Flow_CTL 0078h
69 - 69 69_Additional_Support 4D30h
70 - 74 70_74_Reserved 00000000000000000000h
75 - 75 75_Queue_Depth 001Fh
76 - 76 76_SATA_Capability 850Eh
77 - 77 77_SATA_Additional_Capability 0066h
78 - 78 78_SATA_Feature_Supported 00C4h
79 - 79 79_SATA_Feature_Enabled 0040h
80 - 80 80_Major_Version_Number 01FEh
81 - 81 81_Minor_Version_Number 0021h
82 - 82 82_CMD_Feature_Supported_1 746Bh
83 - 83 83_CMD_Feature_Supported_2 7401h
84 - 84 84_CMD_Feature_Supported_3 4163h
85 - 85 85_CMD_Feature_Supported_4 7069h
86 - 86 86_CMD_Feature_Supported_5 B401h
87 - 87 87_CMD_Feature_Supported_6 4161h
88 - 88 88_Ultra_DMA_Modes 407Fh
89 - 89 89_Normal_SecurityErase_Time 0000h
90 - 90 90_Enhance_SecurityErase_Time 0000h
91 - 91 91_Power_Management_Level 0000h
92 - 92 92_Master_Password_Identifier 0000h
93 - 93 93_Hardware_Reset_Result 0000h
94 - 94 94_Obsolete 0000h
95 - 95 95_Stream_Min_Request_Size 0000h
96 - 96 96_Stream_Transfer_Time_DMA 0000h
97 - 97 97_Stream_Access_Latency_DMA_PIO 0000h
98 - 99 98_99_Streaming_Performance_Granularity 00000000h
100 - 103 100_103_Total_User_Addressable_LBAs 36B037E400000000h
104 - 104 104_Stream_Transfer_Time_PIO 0000h
105 - 105 105_Max_LBA_Range_Entries 0001h
106 - 106 106_Sector_Size 4000h
107 - 107 107_ISO-7779_Inter_seek_Delay_ms 0000h
108 - 111 108_111_WWN 500117310027F454
112 - 115 112_115_WWN_Extension 0000000000000000h
116 - 116 116_Obsolete 0000h
117 - 118 117_118_Sector_Size 00000000h
119 - 119 119_CMD_Feature_Supported_7 4058h
120 - 120 120_CMD_Feature_Supported_8 4018h
121 - 121 121_Expanded_Feature_Supported_1 0000h
122 - 122 122_Expanded_Feature_Supported_2 0000h
123 - 123 123_Expanded_Feature_Supported_3 0000h
124 - 124 124_Expanded_Feature_Supported_4 0000h
125 - 125 125_Expanded_Feature_Supported_5 0000h
126 - 126 126_Expanded_Feature_Supported_6 0000h
127 - 127 127_Obsolete 0000h
128 - 128 128_Security_Status 0001h
129 - 129 129_VU_Capacity_in_GB 01E0h
130 - 130 130_VU_Factory_Max_LBA_LSW 36B0h
131 - 131 131_VU_Factory_Max_LBA_MSW 37E4h
132 - 132 132_VU_Factory_LBA_Expansion 0000h
133 - 133 133_VU_User_Max_LBA_LSW 36B0h
134 - 134 134_VU_User_Max_LBA_MSW 37E4h
135 - 135 135_VU_User_LBA_Expansion 0000h
136 - 136 136_VU_Feature_Enable 0000h
137 - 137 137_VU_Block_HLBA_Setup 0000h
138 - 138 138_VU_AES_Slot 0000h
139 - 139 139_VU_AES_Enable 0000h
140 - 140 140_VU_Default_Idle_Timer_Ticks 0000h
141 - 141 141_VU_Default_Idle2_Timer_Ticks 0000h
142 - 142 142_VU_Default_Standby_Timer_Ticks_LSW 0000h
143 - 143 143_VU_Default_Standby_Timer_Ticks_MSW 0000h
144 - 144 144_VU_Customer 0000h
145 - 145 145_VU_Media_Status 0009h
146 - 146 146_VU_FTL_Feature 0000h
147 - 147 147_VU_Debug_Support 0000h
148 - 148 148_VU_Temperature_Throttle_On 0041h
149 - 149 149_VU_Temperature_Throttle_Off 003Fh
158 - 158 158_FW_String_Right_Justification 0000h
160 - 160 160_CFA_Power_Mode 0000h
161 - 167 161_167_CFA_Reserved 0000000000000000000000000000h
168 - 168 168_Device_Nominal_Form_Factor 0000h
169 - 169 169_Data_Set_Management 0001h
170 - 173 170_173_Additional_Product_Identifier 0000000000000000h
174 - 175 174_175_Reserved 00000000h
176 - 205 176_205_Current_Media_SN 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000080008080808h
206 - 206 206_SCT_Command_Transport FF5Ah
207 - 208 207_208_Reserved 373F10C8h
209 - 209 209_LBA_Alignment 0000h
210 - 211 210_211_Write-Read-Verify_Sector_Count_Mode_3 00003F00h
212 - 213 212_213_Write-Read-Verify_Sector_Count_Mode_2 00000000h
214 - 216 214_216_Obsolete 000020002020h
217 - 217 217_Nominal_Media_Rotation_Rate 2020h
218 - 218 218_Reserved 2020h
219 - 219 219_Obsolete 2020h
220 - 220 220_Write-Read-Verify_Feature_Set_Current_Mode 2020h
221 - 221 221_Reserved 4720h
222 - 222 222_Transport_Major_Version_Number 3046h
223 - 223 223_Transport_Minor_Version_Number 3430h
224 - 229 224_229_Reserved 50420050000032404E00395Ah
230 - 233 230_233_Extended_User_Addressable_Sectors 4331394D44344653h
234 - 234 234_Min_512_Block_Per_FW_Download 444Ch
235 - 235 235_Max_512_Block_Per_FW_Download 5247h
236 - 254 236_254_Reserved 3437302D2D384847313120412020202020202020202020202020202020202020102000800000h
255 - 255 255_Integrity_Word 012Fh
Error Log Index = 4
Checksum = 1
Command # Device Control Feature (7:0) Feature (15:8) Count (7:0) Count (15:8) LBA (7:0) LBA (31:24) LBA (15:8) LBA (39:32) LBA (23:16) LBA (47:40) Device Command Reserved Timestamp (ms)
5 00 00 00 01 00 02 00 00 00 00 00 E0 25 00 0
4 00 00 00 00 00 00 00 00 00 00 00 E0 EC 00 0
3 00 03 00 46 00 00 00 00 00 00 00 E0 EF 00 0
2 00 03 00 0A 00 00 00 00 00 00 00 E0 EF 00 0
1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0
Error Data Device Control Status Error (7:0) Count (7:0) Count (15:8) LBA (7:0) LBA (31:24) LBA (15:8) LBA (39:32) LBA (23:16) LBA (47:40) Device Extended Error Info State Life Timestamp (ms)
00 51 40 00 00 02 00 00 00 00 00 00 0C023100FF00000000000000000000000000 UNKNOWN 5120
5 00 01 00 10 00 00 00 00 00 00 2F 00 00 00 0
4 00 01 00 10 00 00 00 00 00 00 2F 00 09 00 0
3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0
2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 276
1 00 40 00 00 02 00 00 00 00 00 00 51 0C 02 16711729
00 00 01 00 00 00 00 00 00 00 E0 25 6E0000000000000100000000000000402500 RESERVED_9 0
5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 43520
4 00 00 00 00 00 00 00 00 00 00 00 00 14 01 0
3 01 00 00 00 00 00 00 00 00 51 09 05 20 00 0
2 00 01 00 00 00 00 00 00 00 40 25 00 09 00 67108864
1 00 01 00 00 00 00 00 00 00 E0 25 00 6E 00 0
00 00 00 00 00 00 00 00 00 EF 00 00 0000000200000000000000000000EF000000 UNKNOWN 0
5 00 00 00 00 00 00 00 51 0C 02 31 00 FF 00 0
4 00 00 00 00 00 00 00 40 25 00 00 00 00 00 16384
3 00 00 00 00 00 00 00 00 EF 00 00 00 00 00 16777216
2 00 00 00 00 00 00 00 00 EF 00 00 00 00 00 33558528
1 00 00 00 00 00 00 00 00 EF 00 00 00 00 00 512
00 01 00 00 00 00 00 00 00 00 00 14 000000000000000000000000000000000000 UNKNOWN 208
I tried to upgrade firmware, the SSD dashboard says it's up to date!
So I'm kind of at wit's end, I don't really understand all this information. Is there something I should do to reset it so I can format a volume on it?
THANK YOU in advance for helping me out!
