Sometimes it shows up, but it disappers fast again…
Tried 2 computers…
Win XP SP 3…
Tried 2 computers…
Win XP SP 3…
If you’re using MTP mode, make sure you have the latest WMP installed. The MTP drivers actually ship with WMP, not the OS itself.
Okay…i use MCS i think… and thats because i like to have openinmg in a folder so that I ca´n drag and drop files.
I have reinstalled the 2 PC’s since I used the clip last time and I don’t think i have WMP installed…do I need that?
Message Edited by koden on 01-21-2009 11:43 PM
I have now installed WMP 11.
But it does dthe same in all 3 modes…
connect and disconnect short after…all the time…
I just get at window up called portable device and then explorer with my computer/snsa clip 2 GB and then it’s gone…
No files to see in the window…
I have tryed to update, but the updater can’t see the device because it disconnect all the time…
Try connecting it to a rear USB port on your computer.
