write-protection
How do I turn off the write-protection. I am trying to delete some albums off of my fuse+ and I keep getting this message ‘can not delete files, turn off write-protection’. I have looked in settings on my player and found nothing. Please help me it’s driving me crazier.
Try checking the Properties (right-click) on the files in Windows Explorer.
unless you are using it is MSC write protection cant be enabled on the player. you may have a corrupt FAT. if that is the case you will need to format it and reload the songs. i would suggest using the format function in the players settings menu.
I think its corupted. Try to check it again.
