http://www.circuitcity.com/ccd/productDetail.do?oid=184879&om\_keycode=93
It has the same connecter as the e200, so it should…
It is compatible.
Connector wise, its compatible, however you will want to make sure that the dock housing is big enough for the Fuze as its wider than the E200
