I have my Sansa since one month or so, and it worked well since now. When I connect it to my computer, it stay not opened and my computer says he doesn’t recognize it. I think it may be because I didn’t disconnect it well last time, but what can I do?
Thank you.
(Sorry if there is mistakes in the text, English is my second language)
I had the same problem. I solved it by doing a Hardware Reset, per the User Manual (Hold Select and Volume Up <+> simultaneously. It didn’t erase my audio files, just reset the hardware. My computer then recognized it properly.
Worked for me too, my sandisk kept the connected screen on after my computer desided to reset itself (stupid windows update I think) and I couldn’t get it off.
