Is it possible to use the SanDisk Cruzer USB 2.0 Flash Drive without using the password protection (Secure Access). I do not need the encryption on my picture files and some other text files. The transfer of information from the flash drive to the computer and the other way is so slow that I would rather do without the password protection if it is going to be much faster. If it is possible how do you get rid of the password protection or disable it?
sure just simply delete the secure access files and you can use the drive just like any normal flash drive.
how do i delete the password on my sandisk 4gb cruzer?
