Win XP with Windows Media Center 11.0
Sansa Fuze+, Firmware: 2.38.06A
USB mode: auto
I’m trying to use WMC 11.0 to transfer a playlist. The MP3 files got over to the Fuze+ just fine. But there are no playlists. When I try to use Explorer to manually drag over a playlist I get a Windows error like “This file may not be recognized by the device.”
Here are the steps I’m doing per the Sansa web site:
Connect player to the computer.
Start WMC 11. Go to Sync mode (click Sync button near top of windows)
Drag the playlist to the Sync list.
Click the Sync button near the bottom right of the window.
I get an error “Windows Media Player encountered a problem while synchronizing the file to the device.”
Thanks.
EDIT: this isn’t the first problem I’ve had with the Fuze+. Is there another software package for WinXP that will work better than WMC 11? Does Winamp work better? Does Itunes?
