Win 7 won't assign drive letter
I have an Elements 25A2 that I use as a portable drive, it worked fine up until last week when I plugged it into a BELL Sat Receiver to use as a PVR… the BELL did some sort of format on the 25A2 so it would work.
Now when I plug the 25A2 into my laptop or my PC it makes the “USB noise” but does not pop up nor does Win7 assign it a drive letter.
I formatted the 25A2 in Windows in NTFS
I have to go into disk management and assign a drive letter to the 25A2 for it to work.
I have to do this every time now, on my Win7 PC and my Win7 laptop.
Any help would be much appreciated.
Thanks,
Dave
Hi DuckManDave,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support if you are having trouble with the form.
