How do I get my WD to save my documetments and libraries. I have checked inside smartware.swstor and they are not there… I have looked and looked for them and can not find them. I can see then in a search so they are there somewhere. Why can I see other files off the C:\ main directory but not my documents… I just want to be sure they are all there. The reason for my unease is that not all of them can be found… at least when I search and wait a LONG time.
HELP!! - Thanks
You can try changing to “file Backup”. Check page #45 of the WD Smartware user’s manual.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705057.pdf
That was the first thing I did as the software was first set for catigory… Much better now. I will download the manual PDF and give it a good read… I had another drive prior to this that saved everything in the clear. I guess this one saves the documents ion a different format that I can not just open on the drive and look at. Thanks
