Will WD Drive Utilities software see TWO drives?
Hi all,
I have Windows 7 and already have one My Book Duo 6TB connected.  I’d like to connect another drive exactly the same as this.  I have seen the posts on how to get Windows 7 to recognise the second drive, but can anyone tell me if the Drive Utilities software will see this second drive as well?
Thanks,
Paul
Welcome to the Community.
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
Support by Country
http://support.wdc.com/country/index.asp
Thanks.  Will do.
