I like to fall asleep whilst listening to music, will Sansa Fuze 8 gb play at a very low volume. (hope there’s a sleep mode)
What format are recorded voice files.
Hoping you can help as I don’t yet own one.
shadylady wrote:
I like to fall asleep whilst listening to music, will Sansa Fuze 8 gb play at a very low volume. (hope there’s a sleep mode) Yes, there’s even a sleep timer that was added in a firmware update, I think.
What format are recorded voice files. WAV
Hoping you can help as I don’t yet own one. What are you waiting for?
Yes, there’s
WAV
What are you
waiting for?
Thanks for your info. Have just purchased Sansa Fuze 8 gb. and have yet to play with it. It looks the biz, think I will need a case. Will check the firmware update.
I noticed the sleep function when I got my first Fuze, over a year ago. I’m sure that you will find your sleep function.
Just go into Settings -> System Settings -> Sleep, and set the timer to whatever you want. Just don’t choke your self in your sleep with the cord:wink:.
Follow the steps to increase the volume output of your Sansa player:
Clip Jam
Clip Sport
1. Reset the Sansa player to factory settings: Settings > System Settings > Restore
2. Set the region as Rest of World.
3. Change volume setting to High: Settings > System Settings > Volume > High
Clip Zip
Clip+ / Fuze
1. Reset the Sansa player to factory settings Settings > System Settings > Reset Factory Settings
Clip
Fuze+
