eccmd -format stalled and wasn’t even neccessary.
I’ve got 1.3.2 running now!
Thanks for posting Rmast, can you post brief steps on what you did to get it back up and running?
Currently using primocach which is working quite nicely (no random cache resets)
I have just had anothe long discussion with SanDisk support for our region (UK etc) and basically go nowhere.
All they said really was " our engineering department is working on it ".
They would not give any timescales or anything - so unless I use a third party caching product I have a useless 32 Gb SSD in my machine taking up a SATA port.
I really have no confidence in SanDisk fixing this issue even though they could have easily have fixed it either while Windows 10 was being shipped as part of the Insider program or even after version 100240 was shipped - which actually ended up as the version they finally released with a couple of patches.
Any updates I will post here.
Regards
Infinidim
32 or 64 bit and please post how you did it please as there will be a lot of people interested.
Thanks in advance
Infinidim
I don’t have a configuration in which I can reproduce all steps, and don’t know where anyone gets stuck.
My suggestion at this moment (for Windows 10 x64) to get the current install running would be:
Doubleclick on
C:\Program Files\Condusiv Technologies\ExpressCache\excfs\excfs.inf
and
C:\Program Files\Condusiv Technologies\ExpressCache\excsd\excsd.inf
Disable and uninstall PrimoCache if you installed that.
Reboot
remove the 29 GB volume in diskmanager
Run eccmd -partition
Start ExpressCache as you allways would. It should run now without annoying popup.
If it doesn’t or you’re anywhere between install and uninstall:
First, get the (un)install working by clearing Expresscache from registry and files.
If during (un)install the setup still complains there is a previous version installed find the
file ‘expresscache.msi’ on your (Windows) c:-drive during setup.
It must reside somewhere around %LOCALAPPDATA%\Temp with the most recent timestamp.
From (a copy of) the directory run
msiexec /i expresscache.msi /Lv* output.txt
which will give a file output.txt, which contains a pointer to the obstructing remnants.
Uninstall and reinstall expresscache 1.3.2, and follow up the requested reboots.
Now continue at the suggestions at the top, so
Doubleclick on
and
Reboot
Run eccmd -partition to partition the 32 GB Sandisk SSD.
If you still experience issues with (un)install use Revo Uninstaller trial to remove all remnants with a managed uninstall, after reinstalling everything you installed to get things running.
Revo Uninstaller will lookup all files and registry-entries in the MSI that can probably be left by the uninstall.
That’s it.
Please post if you succeed with this manual, or else, what eccmd -info shows… (probably still some licencing issue?)
I didn’t have the folder with the inf driver files but I did have a few alternate installs for ExpressCache, I tried one of those and eventually “setup_x64.exe” gave it to me. I believe that one was posted in this thread.
I ran Revo Uninstaller first to get rid of any old files I had then installed it. I could not run eccmd -partition, it just gave me some error every time and running eccmd -info told me nothing was being cached. I right clicked and installed both of those inf files since double clicking opened them in a text editor. Tried eccmd again and both still said the same. I uninstalled it through Windows I believe and then grabbed ExpressCache 1.3.2 and ran that installer. It took a long time to install the drivers during setup, like 5 minutes or something, it always gave me an error at that point before though which it didn’t do this time. Install finished fine and I restarted then opened ExpressCache which seems to be working.
I currently have 10gb cached and I’ve restarted a few times to make sure my cache wasn’t going to randomly disappear. So yes I have a working ExpressCache now, thank you. I think it was a combination of those inf files and Revo Uninstaller.
Great!
Some of the users have figured out ways to get it to work. I hope Sandisk folks are looking into the methods and hopefully release an installer that gets it done.
Right now, can’t uninstall it and can’t install version 1.3.2 back into the system.
Fast, man. We are waiting.
I’ve still got the same issue. Can’t install.
Still waiting for SanDisk to come back to me with a fix.
Regards
Infindim
Still nothing. lol.
Are they playing hide and seek with us?
I bet the sandisk bosses don’t really know about the whole broken
product and lazy support situation.
@redcache wrote:
Still nothing. lol.
Yes I think that they are playing “hide and seek” with us.
RedCache, have you opened a case with them to get it fixed. I have and I also keep chasing them on a regular basis.
I am also going to raise an issue with Condusiv who write the driver for SanDisk to see whether I can get any leaverage there.
Regards
Infididim
This issue has been escalated to the highest level within SanDisk and we are currently working with Condisiv for a Windows 10 update. While at this time we do not have an estimated date for the update release we have been told we can expect it soon. As soon as I have more information we will provide further updates.
Thank you for your patience and understanding in this matter.
Forum Admin
slotmonsta
infinidim Nope. No service ticket with sandisk.
But I did a live chat and they keep saying the same thing.
I bet Condusiv will reply back to you with an usual “support is provided by sandisk and that they don’t handle sandisk customers.”
Its an embarrasing mess - same as it has been the multiples of times we had to push them around to get **bleep** done.
Unfortunately I am not active on twitter/facebook. Sandisk might be a bit more sensitive to real time poundings in social media.
slotmonsta Sorry, man. No patience here. No patience with lousy actions. Its not only myself. You might see only a handful of people voicing their concerns here. But there are an untold number of people feeling the same way right now. I hope you understand that.
I have received additional information regarding the ExpressCache Windows 10 issue. When updating from any version of Windows to Windows 10 some of the core components of ExpressCache are removed. This results in the uninstall issue customers are seeing. The ExpressCache uninstaller is failing to find components it expects to find resulting in a failure of the uninstall. Unfortunately this uninstall failure prevents a reinstall of the ExpressCache software. We are working with Condusiv to create a tool that will reinstall the components that were removed during the Windows 10 update process. We expect to have this tool available by the end of the month.
If you have not yet upgraded to Windows 10 you can uninstall ExpressCache then upgrade to Windows 10. Once you are running Windows 10 you can install and run ExpressCache normally. Additionally ExpressCache can be installed as expected on a fresh install of Windows 10 since the issue only occurs in the Windows 10 upgrade process.
We apologize for the inconvenience and again we expect to have a tool that will reinstall the missing components that were lost in the Windows 10 upgrade process by the end of the month.
Forum Admin
slotmonsta
Thank Slotmonsta for the news!
Thanks for the update slotmonsta.
But end of the month? How is this tool not made in “a day or two.”
Why doesn’t Sandisk have a proper muscle arm over Condusiv to push them to get things done?
Seems like Condusiv is left to do thingson their own schedule. They obviously need motivation and
proper supervision. Sandisk could use some of the same too.
Bad management from Sandisk side is what it is. Shame.
I think this is one solution. I really dont know if it works, but i am testing it. But: 1- Go to " computer management" , open your explore and choose the " this pc" and after click in “manage” 2- When " Computer management" is open 3- Choose disk management 4- You have to see your SANDISK. 5- Format it, only next, next … 6- After formated, click in “Properties” 7- there is a folder named “READYBOOST” 8- then choose this for "dedicated this device to “readyboost” I think this is the way to turn this on. Regards
Forum Admin
slotmonsta
Thanks for your news but this has been going on since Windows 10 was released and I am sure that the solution won’t fix everybody’s problem that was created because SanDisk becuase they didn’t test this product with Windows 10 before it was released. What will you be doing for those people? Will they have to raise more tickets and wait even longer.
Please make sure that when you have a solution it is well documentred and that you also post what actually has to be removed to make the install work properly so that the more technical people can manually fix it if the Condusiv solution doesn’t work for them.
I am sure that Condusiv will come up with a solution that works - I know the company way back when the original company ( Executive Software ) was formed by Craig Jensen. Executive Software and the company that I was working for at the time were both creating DEC Vax disc software. Executive Software ended up with Diskeeper, we ended up selling our product to them. They have some really clever and good people working for them.
Regards
Infinidim
@slotmonsta Any suggestions?
Clean installed windows 10 only to be able to run expresscache. Everything else was working just fine.
EC should work fine, right?
But ExpressCache can’t find ssd.
-Readycache drive is accessible through disk management.
-Tried to install EC with ssd as both unallocated and formatted.
Same error returned on all tries. (I have a screenshot but can’t attach it to the message)
Any ideas?
