Will a SDHC card work
Will a SDHC card work with this or only micosd
Ok the answer is both KINDA… SDHC refers to capacity and MICRO refers to actual physical area. You have to have a micro sized card in order for it to fit the slot on the player. SDHC are cards that can hold greater than 4 gigs if memory. So you can have microsd or microsdhc
