Will a Class 10 32gb microsd work in my clip+
Patriot, Wintec and Lexar have released 32GB class 10 microsd cards, I was wondering if these cards are compatible.
Wintec is the least expensive on newegg. Patriot being a bit more, I think it’s a bit faster than the Wintec. I have an 8gb wintec filemate microsd from 2007-8 that still works, hopefully their new 32gb is as good.
If the clip+ isn’t compatible with Class 10, I might order a 32gb dane elec class 4 from J&R, which is $64.
Even if it does work, the only time you’d notice the extra speed of the card is if you loaded the card in an external card reader, I believe…so is it worth the extra money for that?
Yes, the 32GB microSDHC cards will work with the Fuze+.  Just be careful that you purchase them from a known supplier (absolutely refrain from eBay!) as there are plenty of counterfeits out there.  32GB is a tasty target for fake cards.
I like the SanDisk cards, as they have a five year warranty.
As far as the speed class, a class 2 or 4 will suffice, as the read / write speed isn’t as critical as in a digital camera.
Bob  :stuck_out_tongue:
The fuze’s read/write speed is about 4 mbyte/s with a class 6 card.  I’m guessing that the clip+ wouldn’t be any different in that regard.
That’s a great price for the Dane Elec card.
