Hi, is there any way to keep wifi going on a PP wireless pro even when plugged in via USB connection?
If you are asking if you can access the files via USB while WiFi remains connected, the answer is no.
If you are asking if you can keep the WiFi active while you’re only charging via USB, then yes – you’ll need to use a charge-only USB cable.
