Why oil free vacuum pump is widely used
The oil-free vacuum pump has the advantages of simple structure, easy operation, convenient maintenance and no environmental pollution. In order to use oil-free vacuum pump products at ease, it is very necessary to choose a regular manufacturer to buy products, and for the sake of operation, it seems that we must follow the instructions in the manual! Today’s products are suitable for many industries and have many advantages. The following is an introduction to the relevant information of the products:
The oil-free vacuum pump has good durability. It is a vacuum pumping, compression and dual-purpose vacuum pump. It is a basic equipment with a wide range of applications to obtain vacuum.
Compared with the oil pump, the oil-free vacuum pump has the advantages of low vacuum degree, small air volume, small size, easy installation, simple maintenance, convenient movement, no oil smoke and no environmental pollution, especially in the laboratory with high requirements. It is also one of the regular equipment in the laboratory. Therefore, when choosing oil-free vacuum pump, the vacuum degree required to work should be determined first. If the true degree of demand is high, the selected vacuum pump should be higher than the required vacuum degree, otherwise, it will fail to meet the requirements of vacuumizing. Secondly, the pumping rate of oil-free vacuum pump should be slightly higher than the required pumping rate in the selection, so as to meet the needs. See if the extracted gas is corrosive. The corrosive gas will corrode the pump. Special materials must be used to meet the requirements.
Oil free vacuum pump products are widely used because of its many advantages. And with the continuous progress of society, the product has made a qualitative leap in all aspects.
