I am respectfully asking you about that when I have connected My Passport to my computer and then check over it during computer management tool, I have found that there is an unlocated partition whose size is about(32MB). And there is a 931GB primary partition. I have updated the operating program for WD by clicking ‘right-click’ and then navigated into My Passport. finally, I have chosen “WD SES Device Driver”, but I noticed that only the question mark whic
What did you reply me in order for I Click the Kudos star to say thank you for helpful posts and be sure to come back and ‘Accept as Solution’ under options for the post that solved your issue.?
I am quite surprised that you are only caring about Kudos star without giving good reply.
I don’t have any problem my freind, but I want to know that support for WD customers is good or not.
In addition, if I help anyone, I don’t help them in order for they give me a kudos, because I don’t care about it at all so long as I am confident of myself.
if you want to know if support is good you should try contacting them
The community is for users helping other users, hence why it’s called " Community "
As long as this forum(community) belongs to WD, there should be some of their designers to view in the customers’ problems.
Joe is right. Us, moderators, are WD employees. However, WD decided that the forum should be a user to user community. That’s because we have Tech Support that is available for helping users. If you want WD help, you can easily get it by either calling or emailing. The link below will get you started.
