Why is My BellSouth Email Not Receiving Emails? - (Easy Fix!)
What to do when you’re having Bellsouth email problems | 1 (855) 666 7787
  • If Bellsouth email isn’t working for you, there are a few potential issues that could be the cause.
  • In some cases, both ad blockers and outdated internet browsers can stop Bellsouth email from working.
  • You should also make sure that you’re sending emails to the correct addresses, and haven’t accidentally blocked anyone.
Many people worldwide communicate using Bellsouth email. That’s why it’s natural to feel frustrated if a technical glitch arises with the email service. One of the extremely annoying issues is when you find your Bellsouth email not receiving emails. This inability to receive and sometimes send emails makes it difficult for most people to carry out their personal and professional communication properly. But instead of getting frustrated and thinking that you cannot continue to communicate, you must try to find resolutions for the problem. Knowing the causes of this issue is essential so you can troubleshoot it well. In this article, you will find how to tackle the issue of Bellsouth email not sending or receiving emails. This will also help you troubleshoot if Bellsouth email not working on Windows PC/Mac or other device. For immediate assistance, you can call customer service line at 1-855-666-7787.
Why am I not receiving emails in my BellSouth email?
If your Bellsouth email is not receiving emails, there must be a critical aspect missing. This is why you aren`t receiving any emails at all. It is quite an issue. Emails sent to your account can stop due to numerous reasons. Here we are naming few:
  1. Server issue: Chances are the AT&T Bellsouth servers are down or under maintenance which is why you are not receiving emails in your Bellsouth email.
  2. Account setting errors: You might have accidentally tweaked the account settings wrongly which is why you are not receiving any emails.
  3. Verify the block list: Accidentally, you might have added the sender’s email ID to the block list, so you are not receiving the email from them in your inbox.
  4. Your browser cache is conflicting: Corrupt browser cache can often cause the browser to misbehave and malfunction.
  5. The AT&T Mail app isn’t updated: An underlying bug might be causing the problem with the app. If so, the temporary error 15 may also show up on your screen but we’ve already discussed how to address it.
Let us now look at the troubleshooting solutions that will help you fix the Bellsouth email not receiving emails problem.
What to do when Bellsouth email not receiving emails?
Before applying any advanced solutions, we would suggest you resolve the problem using the below-mentioned quick fixes.
  • Check if the AT&T servers are down or not. If yes, then all you can do is wait for the servers to go up and if this fixes the issue.
  • Change the browser and check if using a different browser resolves the issue.
  • Try restarting the AT&T Mail app and then signing in with your account to resolve the problem.
  • Sign out and re-sign to your Bellsouth account and check whether this fixes the issue.
  • If you’re using the AT&T Mail app, try reinstalling it.
Let us now apply the advanced troubleshooting solutions and check if this resolves the issue or not.
1. Verify the block list
  • Open Bellsouth.net website on a web browser and sign into your account.
  • Click the Settings icon and select More Settings.
  • Click on Security and Privacy.
  • Check if the sender’s email is listed there. If so, then select it and hit the Delete button.
The above procedure will remove the sender’s email from the blocked list. Now you can ask the sender to send the email and see if this resolves the issue or not. However, that solves the problem only if you’re not receiving emails from one ore more senders that you blocked.
2. Clear the browser cache
  • Launch your browser.
  • Click on the menu icon and select Settings.
  • Select Privacy and Security from the left.
  • Click on Clear browsing data.
  • Check the boxes for Cookies and other site data and Cached images and files options along with Browser history.
  • Hit the Clear data button.
  • Revisit the AT&T Mail website and sign in to your account.
3. Check your Bellsouth Account storage
  • Open AT&T Bellsouth website on a browser and sign into your account.
  • Click the Settings icon and click on More Settings.
  • Check the storage space left in Bellsouth account on the bottom-left of the page.
AT&T Bellsouth email gives 1TB per user for Bellsouth account, i.e. 1000GB. If there is no space left in your Bellsouth email, then you need to make room for the incoming emails. For that, you need to clean up the trash or spam folders. Also, you can take a backup of all the old or large emails and delete the emails that have large attachments that you no longer require.
4. Check the email filters
  • Visit the Bellsouth website on a browser and sign into your account.
  • Click on Filters on the left panel to see all the filters you have created.
  • You can locate and delete the filter that is blocking the email that is being sent to you.
Bellsouth email lets you use up to 500 filters to sort your emails. This a nice feature to quickly jump over to the emails that matter to you. However, having filters can also accidentally send emails to spam or some other folder.
5. Contact BellSouth
If none of the above steps work, it may be time to contact Bellsouth’s support. You can reach out to them via email or call customer support line at 1-855-666-7787 to get assistance with your issue. They will be able to provide you with more personalized support to solve the issue.
In conclusion, if Bellsouth email is not receiving emails, it can be frustrating, but it’s not a problem that cannot be solved. By following the steps mentioned above, you can easily fix this issue and continue using Bellsouth email without any further problems.
Frequently Asked Questions (FAQs):
  • How do I fix my Bellsouth email?
If you’re experiencing difficulties accessing your Bellsouth account or encountering other email issues, the dedicated professionals at BellSouth email support are there to help. You can contact Bellsouth email support by phone at +1-855-666-7787/ (800) 288-2020 (Toll-free).
The browser may be incompatible with AT&T Bellsouth website, or a browser extension could be interfering with Bellsouth’s operation. You may need to clean out the browser cache and cookies. There may be issues with the Bellsouth service or your internet connectivity. Also, privacy settings may be interfering with Bellsouth email.
AT&T has discontinued the bellsouth email domain. All that means is that no new email addresses can be created with that domain. That doesn’t mean the bellsouth domain is not -supported. It still is. To get the help you need with Bellsouth email, call Customer Service at 1-855-666-7787.
  • How do I regain access to my Bellsouth email?
To get started, head to att.com > sign in > enter your complete email in the user ID box > click on Forgot Password. On the next page, type in your email address again in the user ID box, and then your last > click on Next/Continue. The next page will provide you options to reset your password. If it doesn’t, call 855-666-7787.
