Why Is My Arlo Camera Not Connecting to WiFi? - (Easy Fix!)
What to do when Arlo camera not connecting | 1 (888) 336 3359
Learn how to fix the common issues that prevent Arlo cameras from connecting to your WiFi network via the app. Find out the compatible Wi-Fi frequency, router settings, camera placement, and other troubleshooting tips.
Arlo camera not connecting to your Wifi network via app or my.arlo.com web portal can be a frustrating experience. If you have purchase a new Arlo device, and experiencing issues connecting Arlo camera to the internet then this guide will you through the troubleshooting steps to identify the root cause and help to fix the Arlo camera connection issues. For troubleshooting assistance, reach out to live Arlo experts at (888) 336 3359.
Why is my Arlo camera not connecting to Wifi network?
Typically, Arlo cameras won’t connect because you are using an incompatible Wi-Fi network or running a VPN on your mobile device. When connecting your camera, use a compatible 2.4 GHz Wi-Fi network and disable VPN on your mobile device.
That said, a couple of other factors affect the connection process. Here are common reasons for a connection failure;
  • Connecting to a 5 GHz Wi-Fi network. Like most home products, some Arlo cameras support the 2.4 GHz Wi-Fi frequency band. Arlo Pro 5s cams can sync to 2.4 or 5 GHz networks after setup.
  • Poor Wi-Fi signal – insufficient to register and initialize your Arlo camera.
  • Running a VPN or Ad-guard on your mobile device. This masks your device’s IP address; it can’t access other devices on your network.
  • Router settings like MAC address filtering, Firewall, or Port blocking
  • The Arlo camera isn’t within your network’s range
  • Not allowing the necessary location or Bluetooth permission
  • The Arlo camera isn’t in pairing mode – the indicator flashes blue rapidly
Arlo Camera Not Connecting to Wi-Fi – Troubleshooting Guide
  • When setting up the Arlo camera, ensure your mobile device is connected to the same 2.4 GHz and allow the necessary location and Bluetooth permissions. This eases the device discovery process.
  • Ensure the camera is set up (the LED indicator flashes blue) while pairing to the app. This usually lasts about 2 minutes before the camera falls into standby mode.
  • For Arlo battery-powered models, ensure batteries are charged fully before starting the setup process.
  • Try these solutions to get your Arlo camera hooked to your Wifi network and the base station
Power cycle your Devices
  • To refresh your devices, restart the camera and network devices.
  • Power cycling your router refreshes the network connection and clears any IP conflict issues.
  • Unplug the router from the outlet and plug it back in to restart it. Once it initializes and broadcasts an active network, power cycle the camera.
  • Next, reboot the Arlo camera and retry the setup process.
Check Your Network Settings
  • To connect Arlo camera to wifi, there must be an active Wi-Fi network – set to a 2.4 GHz frequency band.
  • Therefore, ensure that your router is set to broadcast on 2.4 GHz. If your router broadcasts the 5 and 2.4 GHz frequencies in a single SSID, turn off the 5 GHz option on the router’s admin portal. Once the camera connects, turn it back on.
  • Alternatively, separate the frequencies into distinct entities with distinct SSID and passwords.
  • While on your router’s panel, ensure that MAC address filtering is off. This option can prevent your router from allocating unrecognizable devices’ IP addresses. Therefore, causing the connection problem when setting up your camera.
  • Keep the Wi-Fi name and password less than 31 characters. Also, ensure that your Wi-Fi password doesn’t contain any special characters that the app could interpret differently. Avoid characters like “ { } $ * ) # on your Wi-Fi password.
  • Ensure that “WPA/WPA2” is the selected Wi-Fi security encryption. Smart home devices are still having difficulty decrypting newer encryption techniques like WPA3.
  • Finally, keep your Wi-Fi network one of channels 1, 6, or 11. Pick a specific channel and reconnect your camera if you have set it on auto.
  • Your mobile device must be connected to the network to which you intend to add the camera. You can move a step further and disable your cellular data.
  • If you make any changes on the admin portal, forget the Wi-Fi network on your mobile device, restart the devices, and connect to the updated Wi-Fi SSID.
  • Before attempting a reconnect, test that your internet works. Now try connecting your camera to test the connection.
Move The Camera Closer to Your Router
  • The signal strength weakens as you move away from the primary router or as the number of obstacles increases.
  • It is always recommended to set up the Arlo camera while close to the router and then move it to the installation.
  • This allows the camera to receive a strong signal during the setup when it is registered to your account and in communication with the cloud servers.
  • To avoid Arlo camera offline issues, ensure the end installation point receives a strong network signal for the indoor and outdoor cameras.
  • If you need to boost your network, upgrade to a mesh network topology or install a Wi-Fi extender.
Disable VPN, Router Firewall, and Ad guard
  • VPN and Ad guard mask your mobile device’s IP address; thus, it won’t communicate with other devices on your network.
  • When running a VPN or ad blocker, your device is virtually on another network, different from your router’s local network.
  • The VPN or Ad guard is likely to block the Arlo camera’s hotspot. You won’t find the network in the list of available ones.
  • Disable the VPN and ad guard when setting up smart devices.
  • Also, confirm that necessary ports aren’t accidentally blocked if your router has an active firewall.
Check your App version.
  • Using an outdated app could be why your Arlo camera isn’t connecting to your Wi-Fi network.
  • Check your respective app store for updates and update if one is available.
  • While checking your app version, clear the cache to refresh its memory and clear up clogged-up log files.
  • With an up-to-date app, you get the latest features and have reduced software bugs.
Bonus Troubleshooting Solutions
  • Try a different cell phone –Sometimes, the connection problem has nothing to do with the Wi-Fi network or the camera but with your mobile device.
  • If you can access a different mobile device, preferably running on a different OS from the one you were using, try it out.
  • Try again later – This is usually applicable and helpful when the servers are down or experiencing connectivity problems.
  • Let things cool down, and retry connecting your robot after a few hours.
Contact Customer Support
If you have given it all you got to no avail, contact Arlo support expert team at (888) 336 3359 for guidance. May be camera needs to be adjusted, or its firmware is corrupt. Contacting the support team should get your Arlo camera up and running in no time
