When I charge the Wireless Stick with USB, it shows White Solid LED and I can’t turn it on, is than any problem?
My Stick is 200G
My Stick is 200G
While charging the Wireless Stick it shows solid Amber light. However you will not be able to use the Wireless functionality as when connected to the USB port of the computer it works as a normal flash drive(MSC device).
