What to do if your Brother Printer is not showing up on the Network?
When your Brother Printer does not show on the Network, it is probably because there was an error in the configuration settings. You can follow the steps below to fix the network issue and reconnect your printer:
  • Step 1: Check the status light to verify if the Brother printer is on.
  • Step 2: Ensure the connection between the router and the printer is secure.
  • Step 3: Install and run the Brother Printer network repair utility tool.
  • Step 4: Verify the IP address of your Brother Printer and your computer.
  • Step 5: Reinstall the Brother Printer software and print a test document.
If you find that the issue is still not resolved you can call the Brother Printer  support and ask for additional technical assistance.
Visit here:**  **Brother Printer  phone  number
Read more: Brother Printer  customer support number
