How large of a SD card can you use with the Shaker? I tried a 2 GIG and it didn’t work but I didn’t know if the problem was the Shaker or the card.
The shaker will support SD cards up to 2GB in capacity
U can also use up to 4G as a card reader. But not to listen to the files.![]()
it can support a max of 2gb. is the card recognized in the pc while its inside the shaker?
Yes a max card of 2GB will be regonized when the player is plugged in.
