What is tWAV?
My Express used to voice record WAV, but now only tWAV. How can I go back to recording voice in WAV format?
Message Edited by jannen on 08-20-2007 11:35 PM
tWAV ???
are u sure??
You probably can change the name of the extension if you are able to rename it.
IE: my files all end in .mp3. If I change my files to end in .mpaoitjaeoig , the file becomes unrecongizable for my computer. But if I fix it, it’ll work again.
But to fix your SE from recording tWavs, something’s wrong with your firmware that’s installed. It might have messed up. If you can update your SE then it should fix that problem.
