What is the best way to fix the QuickBooks Error 1304?
As a QuickBooks user for over seven years or so, I can vouch for the below-mentioned instructions that they are really helpful as steps to eliminate the QuickBooks Error 1304.
  • Open your browser and download the Reimage repair tool.
  • Place the shortcut to your desktop and install it.
  • Run the scan on your system and click on the start repair button after the scanning process ends.
  • After the repair, reboot your system.
 For more on these steps, click here. However, if you require external support, call on xxx-xxx-xxxx anytime.
Troubleshooting Steps to Fix QuickBooks Error 1304
Install QuickBooks 2020 Pro from your computer’s local storage
Put the CD inside the CD ROM of your computer.
Hit Quit if the installation is automatically started.
Right-click anywhere on your desktop in the blank space, hover your mouse cursor at New section, and select Folder.
Enter QuickBooks as the name of the folder.
Now open Windows File Explorer and double-click the CD drive.
Press Ctrl + A to select all the files and then press Ctrl + C to copy.
Navigate back to the QuickBooks folder that you have created on the desktop and press Ctrl + V to paste the copied files.
After all the files are copied to the new folder, double click the setup.exe file to start the installation.
If you are still finding difficulties to solve this issue try to connect to your QuickBooks hosting provider or you can visit apps4rent.
