What is folder navigation and replay gain??What are these two enhancements which were included in the recently released firmware update for the fuze?
Thanks,
SR
Thanks,
SR
Did you read the firmware update post? that should tell you what your questioning about…
Folder navigation is the same way you find things in Windows–by the name of the folder/subfolder you stuck the files in. It’s in addition to the Sansa’s previous way of finding things, which was to read information from ID3 tags in the files to find Album, Artist, Genre, etc.
Replay Gain makes a bunch of songs at various volume levels play more smoothly, without peaks and valleys of volume.
The answer to many questions that begin “what is” can be found in this cool secret website called Google.
