What Hard Drive is used in the My Passport Essential SE 750Gb External Drive?
Here’s the model of the Passport unit of which I am asking WDBACX7500ABK .
What hard drive is used inside the USB enclosure?
Thanks for your help!
They all use Scorpio Blue drives, but of you want to replace it, you won’t be able to do it because the drive circuit board is attached to the drive.
Thanks!
Actually, I was hoping to buy one of these and remove the hard drive to use in my laptop if it was a Sata 300 or 600 hard drive.
At $89, they are cheaper than buying the bare HDD on the internet.
