What "Allocation Unit SIze" should I format my Compact Flash Card for Nickon Camera?
I have a Nikon D700 Camera…
       There are several options when I FORMAT my Compact Flash Memory Card:
  • Default
  • 4096 bytes
  • 8192 bytes
  • 16 kb
  • 32 kb
  • 64 kb
Which one should I choose to get OPTIMUM PERFORMANCE for my D700 Camera?
are smaller or larger Allocation Units better for SPEED or safety ?
Can someone explain the pros and cons of it to me?
my memory card is Compact Flash SAN DISK EXTREME, 16GB, 60MB/s UDMA
:smiley:   Hi Easybullet3,
Dear member of SanDisk Community, welcome.
Friend, for your CF card 16GB, try with:
                     http://www.microsoft.com/en-us/Search/result.aspx?q=cluster%20%20fat32
- For certainty, you can also see in the guide your D700 Camera, on the official website of the same.
Luck.
Regards, Alfred.                                                           (Google translated)
