This issue concerns an external hard drive WD Elements - 500GB (P/N: WDBUZG5000ABK-05, S/N: [Deleted-Privacy]).
In principle the specific hard drive works flawlessly with every computer I have used so far under Windows and Linux with one exception:
When I connect the drive at an HP ZBook 15 G3, it spins up normally but apart from that there is now way to detect the hard drive. I have tried using the Windows disk management and the diskpart command.
I faced the same problem when I tried to mount this drive under linux with the same computer. In /dev there was no entry for the disk. I tried running different hardware detection commands and disk management utilities, but again the drive was not detected.
Some other removable media I tried worked fine with this computer. Any ideas? Thanks in advance
