Hi there, sorry if this is in the wrong spot.
So after saving about 10 gigs of music and 5 gigs of pictures to my WD external from my macbook pro, I try to move them over to my brand new pc yesterday and its not working. When I plug it in (any of the usb ports) I can hear the harddrive starting up, and the light flashing on and off. It even makes the little connecter sound that windows tells you when you plug in something. But its no where to be found, under my disk drives, I see “WD A MK803 External USB Device” but when i open that it just brings it to properties and says “this device is working properly”. I have also installed the lateest drivers for it. Any help would be awesome. Thanks
Austen
