I recently bought a 1tb mypassport and created a separate FAT32 partition in order to play movies on my PS3. Now I set a password for the drive, but obviously this prevented me from being able to use the FAT32 partition on my PS3, and the only way to do so is by removing the password altogether. So my question is whether there is a way to set a paassword for the main NTFS partition with all of my files but keep the FAT32 partition unlocked? Thanks in advance :D
nope…
The Unlocker will no work that way…
It will lock the entire drive
you can try to use another application that allows you to lock only one partition
I don’t have any suggestions at the moment
