Hi
I have MyCloud 4TB, but when I am trying to sync my folders from my computer to MyCloud using WD Sync, it is showing No internet connection detected.
I tried uninstalling, reinstalling, turning off firewall but nothing is working.
Please suggest.
Hi
Please suggest.
Does this happen locally and remotely?Try to check this link to see if it helps you out:
How long have you had your My Cloud and do you know if it’s a first or second generation? Have you read the User Manual for your generation of My Cloud?
Hi Mak,
The issue is coming when I am doing it remotely. The link you shared I have tried that as well but still not working. I have tried two different service providers but the result is same. “No internet connection detected”
Hi Cat0w,
The cloud has been recently purchased. I have gone through the manual for setting up the drive.
