WD Sync crashes when going through setup
Hi!
I have problem with WD Sync Setup. I signed to MyCloud, selected Cloud and clicked next (see picture below). Then I am waiting WD Sync to connect, but WD Sync closes.
I am using MacBookAir 10.11.6 OS version.
I downloaded 2.0.1.72 version of Sync:
WD Sync download
I can access from Android phone, Iphone with MyCloud app, through files.mycloud.com, I’m just struggling to access from MacBook. Does anyone has any solution?
Thank you.
Hi Fanco,
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting
The link below will allow you to call support
Create a Support Case
Create a support case with our world-class service and support team.
