I have a question about WD Smartware running on Windows Home Server. I know there has been a lot of articles on WD Smartware on Windows Vista or Windows 7. Some people report having problems with Virtual CD Manager while others report general problems with WDS.
One thing I haven’t heard much about is insalling WDS on Windows Home Server. I am sure that WDS is not meant for WHS but I installed it anyway. The installation went well but when I go to perform an update, WDS gives me a problem about Net Framework. Basically in order for me to update WDS, I would have to uninstall WDS then update Net Framework then reinstall WDS.
I would like to use WDS to backup Windows Home Server, system file and data, to a WD My Book Drive.
Has anyone been using WDS hand in hand with WHS or WHS 2011 as a backup solution?
