I just connected the new WD 500 My Passwort Essential Drive to my laptop which has WinXP German installation. The drive an software are up to date.
Can I somewhere change my base backup directory? After doing a backup I can only restore from directory: C:\Dokumente und Einstellungen\All Users\ .
It seems not to be able to backup my current logged in base directory C:\Dokumente und Einstellungen\Bob\
How can I change the installation language? The laptop is in use by an english mate too - especially the backup function.
Regards.
hmm
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
**************Exception Text**************
System.ArgumentException: An item with the same key has already been added.
at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at WDSmartWare.Backup.Backup.SetPreferences()
at WDSmartWare.Backup.Backup.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
**************Loaded Assemblies**************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3603 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
WDSmartWare
Assembly Version: 1.2.0.8
Win32 Version: 1.2.0.8
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/WDSmartWare.exe
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Tanagra.DataClad
Assembly Version: 2.0.0.1
Win32 Version: 2.0.0.1
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/Tanagra.DataClad.DLL
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Tanagra.Utility
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/Tanagra.Utility.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Memeo.API
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/Memeo.API.DLL
XMLSettings
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/XMLSettings.DLL
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Tanagra.DataClad.DataAccess
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/Tanagra.DataClad.DataAccess.DLL
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Tanagra.BMU
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/Tanagra.BMU.DLL
System.ServiceProcess
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceProcess/2.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Tanagra.Interop
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/Tanagra.Interop.DLL
SQLite.NET
Assembly Version: 0.22.0.0
Win32 Version: 0.22.0.0
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/SQLite.NET.DLL
Tanagra.BMU.Providers.HardDiskBackupProvider
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/providers/Tanagra.BMU.Providers.HardDiskBackupProvider.dll
Tanagra.BMU.Providers.FileCopyBackupProvider
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/providers/Tanagra.BMU.Providers.FileCopyBackupProvider.DLL
Tanagra.Third-party.Security
CodeBase: file:///C:/Programme/Western%20Digital/WD%20SmartWare/Front%20Parlor/Tanagra.Third-party.Security.DLL
System.Web
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
wlhgbf2m
crlhpvjr
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
**************JIT Debugging**************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
