I never bought one stuff with so many problems as MY Passport:
1st: the TABs Backup and Restore were not available. After install, remove, reinstall, download new versions and had a LOT of problems was able to access those tabs
2 nd: I can’t see even 50% of my directories in the drive C.
3 rd: Also the firmware upgrade does not work.
Consulting the support area and the WD Community I can see many users desperate like me with no response to their problems.
I gave up to use the software and I’m doing the backup manually.
This is really very, very bad.
Even the registration screen in the WD Drive Utilities doesn’t work
