WD Smartware 1.2.2.5 Fails on MAC OS X
I updated the WD Firmware on my myBook Essential and installed the Smartware 1.2.2.5 update as per instructions. A small “Smartware” icon appears up in the menu bar, but when I tell it to “Open Smartware”, smartware starts and fails. This is the error that appears in the log:
6/26/10 11:08:38 AM    WD SmartWare[679]    *** Assertion failure in -[NSTextFieldCell _objectValue:forString:errorDescription:], /SourceCache/AppKit/AppKit-1038.32/AppKit.subproj/NSCell.m:1531
6/26/10 11:08:38 AM    WD SmartWare[679]    Exception raised during posting of notification.  Ignored.  exception: ‘Invalid parameter not satisfying: aString != nil’  invoked observer method: ‘*** -[AppDelegate applicationWillFinishLaunching:]’  observer: 0x190c570  notification name: ‘NSApplicationWillFinishLaunchingNotification’
Hopefully someone at WD can use this information to fix this bug.
I use MAC OS X 10.6.4 on a MacBook Pro w/Intel CPU and 4GB memory.
I am having the same problem.  It will not update 1.1.1.4 on Mac OS 10.5.8.  I also find that every time I want to backup it asks me to install software.    What do I do?
I have been having the same issue as well. I have a Macbook Pro with 4 gigs of Ram running off of Mac OS 10.6.4  I have tried to update my drive to the latest Smartware software 3 times and it doesn’t seem to take everytime.  Even though I follow the software update instructions.  I am not sure what the issues.
I am having the exact same problem.  My Passport Studio came with old drivers and firmware where WD Smartware would appear to install, but when i tried to open the software, nothing would happen.   The e-ink on My passport only showed VIDEOS 09 only.  I found the update on the WDC.com website and installed that as per the instructions.  Install went smoothly.  But when i click on WD icon in top bar on MAC OSX and select OPEN WD smartware, nothing happens.  But after firmware i now have more info showing on e-ink screen.  Seems very flaky to me.  Is WD working on a fix for this?  The software isn’t usable.
Finally got it working thanks to WD support.
got to system preferences >share, and then add a computer name to see if that solves the problem.
Same problem on my new WD 2TB disk (bought today), no update. I’ve noticed that if I copy the application (coming from the WD partition) in my Applications folder, this is deleted by the update process.
I don’t know what adding a computer name is related with this, but I’ll give it a try.
Well, nothing to do. It doesn’t work at all.
