I got the WD Sftware (Not Win 7) Safely Remove option to work.
I removed the MyPassport Ultra - BUT THEN seconds later - a pop-up stated it couldn’t find the path to the My PPt Ultra and to – Please Re-Insert the drive --.
I Re-Insert and thankfully all data reappears as though nothing is wrong.
Fairly SURE it worked ONLY because ONE My PPt was inserted; IF my (2) My PPts are inserted (Only 1 drive BkUp is Enabled at a time) the “Drive in Use” always appears.
IS the Re-Insert pop-up more of a Glitch than a Real requirement? Would be somewhat helpful to have limited use of this function. MANY THANKS!
