Hallo,
i have a problem with Quick View. Quick View runs and it shown my Cloude Mirror. Now i delete my Cloude off in the list at Quik View. If there any way to reconfigure Quick View so my Cloude will be show again?
Greets Zlaus
Hallo,
Greets Zlaus
What OS are you running on your computer?
Have you tried a reboot of your computer? As mentioned in prior post what make of computer are you using, Windows, Apple, Linux etc.?
I’m using a PC with Windows 10.
And Yes… I Reboot my PC Mans times since.
Try a download and reinstall of Quick View or go to Control Panel>Programs>Programs and Features, select Quick View and then at the top select repair and try that.
http://setup.wd2go.com/?mod=download&device=mc
I did it all… but nothing happens…
My WD Mirror is not shown in list.
