WD Problem
i baught WD My Passport Ultra 1tb
and it started to cause troubles after 3 month (Fatel Error , Windows Stop Working For A Reason Etc’)
so i read about this case. and i deleted Volume and then format and from some reason it Went to RAW and from there i just mast it up so now its
GPT Protective Partition.
i really dont know what to do i also tried all the drivers possible (Utility’s Etc’)
hope you’ll help me with this one thanks alot.
Try writing zeroes to the drive using WD DLG and then try formatting the drive again.
Data Lifeguard Diagnostic for Windows
