My Portable says it is full and there is NOW WAY. Anyone solved this problem?
Did you manually check the total used storage of portable drive?
Thank you for answering my plea for help! I do not know how to check for total storage use. Could you tell me?
Sue
You may check the Properties of your external hard drive and under Storage tab, you will get the used storage details.
