# WD Passport not loading
**URL:** <https://forums.sandisk.com/t/wd-passport-not-loading/313380>\
**Category:** Portable SSD\
**Created:** [January 10, 2023, 6:56pm UTC](https://forums.sandisk.com/t/wd-passport-not-loading/313380 "2023-01-10T18:56:10Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Peter\_Dagger](https://avatars.discourse-cdn.com/v4/letter/p/838e76/32.png) [@Peter\_Dagger](https://forums.sandisk.com/u/Peter_Dagger)\
**Post date:** [January 10, 2023, 6:56pm UTC](https://forums.sandisk.com/t/wd-passport-not-loading/313380/1 "2023-01-10T18:56:10Z")
</div>
Hi Guys I have a 5tb WD passport and it simply won’t mount onto my Mac/ pc or MacBook, the cable is checked and working with an alternate drive, but the Wd passport doesn’t appear to mount
**Post date:** [January 10, 2023, 6:57pm UTC](https://forums.sandisk.com/t/wd-passport-not-loading/313380/2 "2023-01-10T18:57:47Z")
</div>
It appears in terminal
 ![Screenshot 2023-01-10 at 18.56.48](https://global.discourse-cdn.com/sandisk/original/3X/4/2/4204c01447eafd77576e4388da6710ffbca9e37c.png)
**Author:** ![Keerti\_01](https://avatars.discourse-cdn.com/v4/letter/k/9fc348/32.png) [@Keerti\_01](https://forums.sandisk.com/u/Keerti_01)\
**Post date:** [January 12, 2023, 10:05am UTC](https://forums.sandisk.com/t/wd-passport-not-loading/313380/3 "2023-01-12T10:05:30Z")
</div>
Hi @Peter_Dagger,
Please refer to the article Windows or macOS Cannot Find My Drive:
> **[Western Digital Support | Western Digital](https://support-en.wd.com/app/answers/detail/a_id/12455)**
> Find detailed answers to your support questions for your Western Digital, SanDisk, WD\_BLACK, or WD storage product.
Please contact the WD Technical Support team for best assistance and troubleshooting:[https://support-en.wd.com/app/ask](https://support-en.wd.com/app/ask)
**Author:** ![Jose2020](https://avatars.discourse-cdn.com/v4/letter/j/c37758/32.png) [@Jose2020](https://forums.sandisk.com/u/Jose2020)\
**Post date:** [January 13, 2023, 5:55am UTC](https://forums.sandisk.com/t/wd-passport-not-loading/313380/4 "2023-01-13T05:55:10Z")
</div>
When you connect an external hard drive on Mac, it will show up on Desktop, Finder, and Disk Utility. But sometimes the external drive won’t appear on any of these places. To fix the issue, you can try the below methods:
1. Change MacOS settings under Finder preferences
2. Reset (NVRAM/PRAM/SMC) Mac firmware settings
3. Fix external hard drive connectivity issue
4. Mount or Repair the external hard drive using Disk Utility
Further, I suggest you to check the below link for detailed steps to be followed in each method above.
> **[Resolve External Hard Drive Not Mounting on Mac](https://www.stellarinfo.com/blog/resolve-external-hard-drive-not-mounting-on-mac/)**
> Change Finder settings, reset firmware, or fix hard drive connectivity issues to fix the external hard drive not mounting on Mac issue.
Hope it helps!
