WD Nomad For My Passport Ultra 2 TB
Is the WD Nomad compatible with My Passport Ultra 2 TB ?
As you might be aware it has not been tested since one came out after the other.
Just by looking at the specs for the My Passport Ultra looks like it could be a bit loose on the WD Nomad.
Lets see if one of the users of the community has already tried.
Edit:
Checked the specs for both the Ultra and the regular My Passport and they are about the same width therefore it should fit.
The difference in height is not a problem since the Nomad comes with a rubber piece for that.
Will try to test later on here and post back my findings.
Thank you for your explanation, I hope this WD Nomad could fit My Passport Ultra 2 TB, I really like the WD Nomad, I think this is a good case. I will wait your test for WD Nomad and My Passport Ultra. I really appreciate your help :slight_smile:
