WD Nomad Case compatibility
I have a WD My Passport 1 TB of product ID WDBBEP0010BBK-01. I want to know if my drive will fit into the WD Nomad case.
According to the specifications sheet for the WD Nomad carrying case, the model that you are  mentioning is fully compatible
Check the link below for the full specifications.
http://www.wdc.com/wdproducts/library/AAG/ENG/4178-705180.pdf
