Brand new laptop, when i plug the drive in via usbc and try to copy a file off it starts then the transfer slows down to 0 and it sits there for a while then disconnects and windows tells me the drive has malfunctioned. I have another laptop which this doesn’t happen on but this happens to this one laptop when plugged directly into usbc port or through a usbc hub. It does not happen when using the supplied usbc to usba adapter, or when plugged in to a usbc hub using the usb a adapter. I have two of these and they both do this same thing when copying files off
Event logs from incident
Information | 04/06/2020 14:31:48 | OED | 19 | This task logs error codes to system event log. |
Information | 04/06/2020 14:30:50 | OED | 19 | This task logs error codes to system event log. |
Warning | 04/06/2020 14:30:49 | DistributedCOM | 10016 | None |
Information | 04/06/2020 14:30:19 | OED | 19 | This task logs error codes to system event log. |
Error | 04/06/2020 14:30:19 | disk | 11 | None |
Information | 04/06/2020 14:30:19 | mrcbt | 7 | None |
Warning | 04/06/2020 14:30:19 | disk | 51 | None |
Warning | 04/06/2020 14:29:52 | disk | 153 | None |
Error | 04/06/2020 14:28:03 | mrcbt | 2008 | None |
Warning | 04/06/2020 14:28:03 | DistributedCOM | 10016 | None |
Information | 04/06/2020 14:28:03 | mrcbt | 1001 | None |
Information | 04/06/2020 14:28:03 | Ntfs (Microsoft-Windows-Ntfs) | 98 | None |
Error | 04/06/2020 14:28:00 | disk | 11 | None |
Information | 04/06/2020 14:28:00 | mrcbt | 5002 | None |
Information | 04/06/2020 14:28:00 | mrcbt | 5007 | None |
Information | 04/06/2020 14:28:00 | mrcbt | 5006 | None |
Information | 04/06/2020 14:28:00 | mrcbt | 1005 | None |
Information | 04/06/2020 14:28:00 | mrcbt | 4 | None |
Log Name: System
Source: disk
Date: 04/06/2020 14:29:52
Event ID: 153
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: MICHAEL-10-2
Description:
The IO operation at logical block address 0x1ddd68 for Disk 3 (PDO name: \Device\000000c8) was retried.
Event Xml:
153
0
3
0
0
0x80000000000000
2431
System
MICHAEL-10-2
\Device\Harddisk3\DR10
0x1ddd68
3
\Device\000000c8
Log Name: System
Source: disk
Date: 04/06/2020 14:30:19
Event ID: 51
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Description:
An error was detected on device \Device\Harddisk3\DR10 during a paging operation.
Event Xml:
51
0
3
0
0
0x80000000000000
2432
System
MICHAEL-10-2
