WD My World Book - Does not Connect Wirelessly
Had the device for at least 6 years. Worked well till now. A few variables:
Just moved but it connect fine to the wireless network and was able to use.
Cannot access the device IP to access the admin tools. Is the default IP 10.0.0.3?
Ive reset using the reset button, as I dont want to lose what is on the HD. Now the light is going up and down, which I think means that it is in running mode and its been doing that for at least 15 minutes.
Using FE Explorer App, which has worked fine, I get an error message that it cant open files.
Any ideas on why I cannot connect?
Hello, Searsba,
Maybe you should try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
Thx. Found that my ISP needed an update on router which fixed the problem! Thx for responding
Barry Allen Sears
