WD My Passport Ultra 2TB Not Detected
Hi, so my WD My Passport Ultra 2TB used to work perfectly and then one day a few months ago it made these click sounds but my Macbook Air was able to detect it and after a few hours within that same day, the click sounds stopped. And just recently, maybe a week ago, it made these click sounds again but it was still detected then it was suddenly undetected then made these beeping sounds and some click sounds. Then just a few days ago, the beeping sounds stopped so it only makes these click sounds now. It’s still not detected ever since. PLEASE Help!
Edit: During the time when it was making beeping sounds and click sounds just last week or something, it showed up (detected) one time but it seemed to still be loading so it was showing nothing…
Also, I remember my laptop bag with my hard drive in it falling on the floor (tiles) from a chair maybe 30 inches high. Before this happened, my hard drive was working well then after this happened, the problems i said/have been encountering started happening…
It is possible the drive suffered some damage from the fall.
I recommend you try to get your data out and then get a replacement.
Yes, I’m getting it checked today.
Thanks for the feedback!
