I have my external Harddrive for about 1 1/2 year. It always worked fine. Last Thursday it stopped. Suddenly it wasn’t recognised anymore and it slows down my computer until halt. And it stays like this until I remove the harddrive again.
After I remove it the computer works fine again and I get a little popup from Windows that tells me “You need to format the disk in drive E: before you can use it.” I don’t want to format it, because I have lots and lots of data on that drive. I made a backup from my computer I formated for an upgrade and now - if I can’t get the data recovered - they are all lost.
I tried already the WD LifeGuard Diagnostics but my harddrive is not recognised at all, so I can’t check of any faults.
It is not recognised in the Diskmanagement either. Sometimes - very rarely though - I see under “Computers” in the Explorer “Local Disk” (no Drive number).
I cross checked already with another cable, another computer and even another OS. No luck.
I tried to register the drive for creating a RMA but there seems a problem on the WD Website.
I don’t want to give up that drive. Can please someone help me?
Thank you in advance
