I bought WD My Passport Portable SSD 1TB(STARTS WITH WDBAGF). But this device not available in WD Discovery/WD Backup/WD Security. I installed last versions from site and also failed to found my device in this apps. Although the device is visible in the explorer of Windows 10, and I can work with it. For example others my WD My Passport HDD devices works fine with all apps.
You may refer to the following link: WD Discovery: No Apps or USB Drives Detected After Download, Install and Update
