I attempted to use a My Passport 4TB drive on Desktop pc running Windows XP. It is not visible in My Computer but it is visible in device manager and in the taskbar under safely remove hardware. It blue light on the front is lit but I am unable to add files or view files that are on it. Does anyone have an idea what the issue could be. Thanks
Hi Wiggtown1,
Please know that WD My Passport 4 Tb drive is supportable on windows 7, windows 8 and windows 10. For more information, you can refer the link given below to know about product specifications of your WD My Passport drive.
For more information, you can contact WD’s Technical Support from the below mentioned link.
The link below will allow you to call support.
